| I will not function if you break my heart. |
pic: First off season project
Re: pic: First off season project
Looks good. Why did you stuff wood into the vertical electronics board supports? The aluminum tubing should be strong enough to hold an electronics board, especially if you add a cross brace.
Btw, H-drive describes 5 omniwheels in a H shape, and this is not a H-drive. I'm not sure what it would be called though (omnidrive?). Good luck, and I hope to see a video of this moving soon! ![]() |
I think this could be called a kiwi drive, or maybe just a holonomic drive if it turns out that kiwi drive only refers to drives with three omni wheels.
Nice work! What drove your design to put electronics up top? Even if you do that, I recommend putting the battery down low to lower the center of the mass. |
Being from the team that coined the name "kiwi", I really only consider it for 3 wheels. (Though since this chassis is approximately round and not a rectangle, I can see the case being made that it's a 4-wheel kiwi)
Coincidentally, we actually officially named our project the "poor man's swerve drive" because of its ability to drive in any direction and because of our limited budget in which we had to go over by an amount in which will remain undisclosed Our electronics captain decided to put the electronics at the top simply because the project was originally to build just a chassis. We're actually integrating a battery holder/tray/bracket (whatever you want to call it) into our cross supports, along with that we are going to cut a rectangular hole into the center of our lexan electronics board that will be large enough for the battery to slide through and down into the holder tray. The battery will sit in the middle of the robot. |
#10
On several threads, I've seen this layout referred to on CD as a Killough drive, named after the man who invented holonomic drive. His drive had three ball wheels, and more closely resembled kiwi.
#11
To execute it, 931 had to build custom transmissions and omniwheels. It is difficult to overstate the impact that AndyMark and VexPro have made on the FRC community, by enabling teams without extensive fabrication means to explore and test design concepts at (relatively) modest cost. |
#12
Quite literally everyone and their Dog in FTC used a similar drivetrain like this to achieve holonomic motion. This could be the first time I've seen someone build an FRC version, but I haven't looked too hard either.
I hope you post some video of how it drives sometime! |
#14
I believe AndyMark used to sell one similar.
#15
