Go to Post Glue it, screw it, bolt it, rivet it, weld it. If the design is flawed it will fail. - Gdeaver [more]
Unread 21-11-2015, 16:42
z_beeblebrox's Avatar
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
Re: pic: Wood Coast Drive V2
Originally Posted by nuclearnerd View Post
What size bed do you need for this one? ~3 ft squareish?
Our laser cutter bed is 29x17", but parts up to 29x34" can be cut in two operations, one for each end, by opening the machine's door so the material can stick out.
Really digging the black. Are you just staining black, or will anything be green?
What made you go with 12 fps single speed over something faster like 16-17fps or a shifting gearbox?
What is the overall weight for this model, minus electronics?
That battery mount is gorgeous.
Cound you post screenshots of the plywood wheel in detail? That in particular looks really interesting.
-Our final color scheme is TBD.
-Gearbox ratios can be easily changed for free speeds from ~9 ft/s to >20 ft/s, depending on the distances normally traveled in the game. The chassis could easily be modified to use ball shifters, mounted like this.
-Excluding electronics and hardware not shown in the model and including motors and belts, the drivetrain weighs ~28.4 lbs.
-Images of the wheel can be found here. The only difference is that 6 dowel pins are used in each wheel in the album, as opposed to 3 in the robot's wheels.
