Go to Post Pro safety tip: put a string through coil springs that is tied off securely on the robot frame. This will help prevent the spring from jumping out and killing an inspector if it snaps. - Ninja_Bait [more]
Unread 25-11-2015, 14:05
Jared Russell's Avatar
Taking a year (mostly) off
Re: paper: Team 1114 2015 Code Release (Java)
I love reading code for great robots with a high level of automation. You can tell just how much time was spent optimizing everything.
One question. I noticed in your autonomous driving code, you do some compensation for voltage level:
Code:
Vect output = new Vect(xOut*12.5/voltage, yOut*12.5/voltage);
Did you find that this made a significant difference in your application as opposed to just outputting xOut and yOut directly? It looks like you had both modes available, so you must have done some sort of comparison.
