Go to Post Whether or not you use wheel weights, if you're running a wheel at several thousand RPM, you'd better have an effective containment system to protect the outside world in case something spontaneously disassembles itself. - Alan Anderson [more]
Unread 29-11-2015, 00:09
RobotsThatWork's Avatar
RobotsThatWork RobotsThatWork is offline
AKA: Adithya Bellathur
FRC #0649 (M-SET Fish)
RobotsThatWork is an unknown quantity at this point
Re: pic: Updated strafe module force diagram
Quick question: is F the frictional force exerted by the carpet? or is it the wheels exerting force on the carpet? It looks like the force exerted by the carpet due to the direction, but I just want to clarify
Unread 29-11-2015, 09:42
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Yes, I've done a force diagram of the wheel/gear system; all of the forces are acting upon the wheel and/or wheel gear.
D acts normally to the pressure face of the wheel gear. It is actually composed of elements at several teeth, the ones above further right, the ones below further left.
B essentially acts along the axis connecting the drive axle and the wheel axle. The main part of B is the reactive force of the chassis to the drive. As it is acting through the drive bearings, it must act through that axle. The pendulum return of the module and the by-product of the forces on the floating wheel are argued to be insignificant.
