Go to Post The spirit of FIRST lives in all of them[us]. Knowledge is power and the unknown is scarey but in the end the spirit of FIRST will endure. - LSevcik [more]
Unread 01-12-2015, 18:24
Bryce2471's Avatar
Bryce2471 Bryce2471 is online now
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Re: pic: WCD off season chassis from 2471
Originally Posted by Ty Tremblay View Post
What lead you to choose to use tensioners with your design?
I was not involved in that decision, so I can't say for sure. However, I do know that bearing blocks were used so that the the frame could use .0625in wall tubing.
FLL Team Future imagineers
FRC Team Mean Machine
Unread 01-12-2015, 18:46
Do I spy shock absorbers? Or is that black ABS for spacing?
GitHub
Unread 01-12-2015, 21:44
RobotsThatWork's Avatar
RobotsThatWork RobotsThatWork is offline
AKA: Adithya Bellathur
FRC #0649 (M-SET Fish)
RobotsThatWork is an unknown quantity at this point
for your chain in tube design, are you using 2"x1" tubing? if so, are you using COTS sprockets? I haven't been able to fit 2 COTS sprockets into the tube. It would be great if anyone could tell me how everything was packaged together.
Unread 01-12-2015, 22:00
Greg Woelki's Avatar
Greg Woelki Greg Woelki is offline
FRC Alumnus
FRC #1768
Greg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of light
I can't speak for team 2471, but these fit. A version broached for 1/2" hex is available in the drop down selection box.
Unread 01-12-2015, 22:15
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Yes, and yes. They are plastic spacers. We designed the bumper mounts that way to help insulate the frame from impact. This year's BunnyBots competition has no rule against high speed ramming, and looks to be highly violent.
It was designed to use standard vex spockets, but because they were out of stock, we ended up using steel sprockets with shortened hubs. I don't know the exact layout.
Very nice, I was unaware that they were availible in hex.
Unread 01-12-2015, 22:12
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
I'm not sure how cots sprocket don't fit? Do they not fit due to the diameter or the width of the sprocket or both?
R.C.
MadTown Robotics Team 1323
Unread 01-12-2015, 23:06
Two 16 tooth vexpro sprockets do not sit next to each other inside the 2x1x1/8 (so width). This is true for both when bearings are press-fitted, and when I use a versa bearing block. The Sprocket with Chain attached to it has a total diameter of 0.491 inches. When I put 2 back to back it would be too wide to fit inside the boxtubing. Any solutions?
I haven't looked into the 17 tooth double sprocket, but can you create a dropcenter with the larger diameter? I know the clearance is pretty slim already for 16t, but I don't know for sure with 17t.
Unread 02-12-2015, 07:59
pribusin's Avatar
pribusin pribusin is offline
Uber Alien
AKA: Mike 1
FRC #4004 (M.A.R.S. Rovers)
pribusin has a spectacular aura aboutpribusin has a spectacular aura aboutpribusin has a spectacular aura about
Very nice and clean drive base. I want our team to look into a chain-in-tube design this year but I've always wondered how you assemble the chain and sprockets in the tube Care to give me some insight on the procedure? Are there access hole on the underside? Has anyone ever done this with belts?
Unread 02-12-2015, 08:09
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
What we've done is loop the chains around the sprockets and then drop the entire thing down into the tube. Then slide the axles through the sprockets and the bearings over the axles. This is of course 100x easier if the tubes are not attached to the robot already.
If you are using 2 sprockets in the middle like we do we have a small piece of axle that we'll put through the two sprockets to hold them together during the drop and push that piece out with the final axle.
Unread 02-12-2015, 08:52
pribusin's Avatar
Uber Alien
AKA: Mike 1
Got it - thanks.
Are those 3" x 0.875" wheels? How are they kept from slipping off the hex shaft?
Unread 02-12-2015, 12:37
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Got it - thanks.
External retaining rings: http://www.mcmaster.com/#97633a200/=102dny4
#banthebag
#RIBMEATS
#1620
Unread 02-12-2015, 12:48
Nebster's Avatar
Nebster Nebster is offline
AKA: Ben Kishter
FRC #1306 (BadgerBOTS)
Nebster is an unknown quantity at this point
What are you using to hold the corners of the frame together? It's not clear to me
2015 Wisconsin Regional Chairman's Award - Carson Division
2013 Wisconsin Regional Chairman's Award - Curie Division
Unread 02-12-2015, 12:52
Flywheel Police
There are blocks in the ladders with through bolts going through the rails.
Unread 02-12-2015, 13:00
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
http://www.team221.com/order.php?cat=15
See "Chassis Tube Connector"
Unread 02-12-2015, 14:46
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
This was a point of much discussion while in the design phase. We thought gussets would be stronger, but using blocks would fit with the chain in tube solution better.
This is what we ended up going with, partly because the belly pan is adding a lot of corner to corner strength already.
We did not use these, but they look to be functionally equivalent. The plastic blocks ended up being a good project for younger students to get some training and experience in.
