Re: pic: WCD off season chassis from 2471
I haven't looked into the 17 tooth double sprocket, but can you create a dropcenter with the larger diameter? I know the clearance is pretty slim already for 16t, but I don't know for sure with 17t. |
Very nice and clean drive base. I want our team to look into a chain-in-tube design this year but I've always wondered how you assemble the chain and sprockets in the tube
Care to give me some insight on the procedure? Are there access hole on the underside? Has anyone ever done this with belts?Last edited by pribusin : 02-12-2015 at 08:07. |
If you are using 2 sprockets in the middle like we do we have a small piece of axle that we'll put through the two sprockets to hold them together during the drop and push that piece out with the final axle. Last edited by notmattlythgoe : 02-12-2015 at 08:25. |
Got it - thanks.
Are those 3" x 0.875" wheels? How are they kept from slipping off the hex shaft? |
What are you using to hold the corners of the frame together? It's not clear to me
There are blocks in the ladders with through bolts going through the rails.
See "Chassis Tube Connector" |
#10
It would be interesting to see the FEA for the block vs gusset design. On my team the thought was that blocks were stronger because the blocks were pulling the frame members toward each other.
#12
I can not find the round version. Am I missing something on the website?
#14
The 17t sprocket works in the 2 x 1 x 1/8 because it has a large enough pitch diameter that the chain clears the 1.125 bearing OD. Last edited by Nate Laverdure : 02-12-2015 at 10:32. |
