Re: pic: WCD off season chassis from 2471
See "Chassis Tube Connector" |
It would be interesting to see the FEA for the block vs gusset design. On my team the thought was that blocks were stronger because the blocks were pulling the frame members toward each other.
I can not find the round version. Am I missing something on the website?
Wait, Mean Machine's not doing swerve?
![]() Glad to see you're having fun and building robustly for BunnyBots -- should be a fun event. |
What are you doing for center drop? Do the sprockets you're using inside the tube have enough clearance with the walls of the tubing for a center drop? I haven't seen that done before but since you're using 1/16" tubing it could be possible.
Do you feel 1/16" walled tubing is strong enough for a traditional drive train? Last edited by Nebster : 04-12-2015 at 17:49. |
#10
![]() Quote:
Anything that survives this BunnBot game will certainly be "strong enough for a traditional drive train" |
#11
Yes, 1/16 wall tubing is easily strong enough for a drivetrain.
#12
Generally, 1/8" wall (or .1" wall) tubing is used on the driveline in order to support the bearings or internal bearing blocks better. 1/16" is too thin for a drivetrain bearing fit not supported by anything else. So regardless of strength many teams run 1/8" wall on the driveline. This could be different for systems like the VersaBlock which don't rely on the internal walls of the tube for support. As for your cross members, I have heard in the past that teams have dealt with buckling cross members under very heavy defense when they used 1/16" 2x1 tubing. This obviously depends on the number of crossmembers used, any other cross-structural support from other mechanisms, etc. but I wouldn't just say "1/16th is easily strong enough" as a general statement. |
