Go to Post everyone loves photoshops of Dave... - lukevanoort [more]
Unread 02-12-2015, 14:46
Bryce2471's Avatar
Bryce2471 Bryce2471 is online now
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Re: pic: WCD off season chassis from 2471
Originally Posted by Nebster View Post
What are you using to hold the corners of the frame together? It's not clear to me
This was a point of much discussion while in the design phase. We thought gussets would be stronger, but using blocks would fit with the chain in tube solution better.
Originally Posted by notmattlythgoe View Post
There are blocks in the ladders with through bolts going through the rails.
This is what we ended up going with, partly because the belly pan is adding a lot of corner to corner strength already.
Originally Posted by Ty Tremblay View Post
http://www.team221.com/order.php?cat=15
See "Chassis Tube Connector"
We did not use these, but they look to be functionally equivalent. The plastic blocks ended up being a good project for younger students to get some training and experience in.
FLL Team Future imagineers
FRC Team Mean Machine
Unread 02-12-2015, 16:01
cxcad cxcad is offline
FRC #1683 (Techno Titans)
It would be interesting to see the FEA for the block vs gusset design. On my team the thought was that blocks were stronger because the blocks were pulling the frame members toward each other.
Unread 02-12-2015, 21:48
zinthorne's Avatar
zinthorne zinthorne is offline
AKA: Avery
FRC #5827 (Code Purple)
zinthorne will become famous soon enough
Does anyone know where to find a cad file for this?
The half inch hex
Unread 02-12-2015, 23:24
The half inch hex
Because I couldn't find it, I just downloaded the round version, put a hex bore in it, re-saved it as a STEP file, and reopened it. That gave me the 1/2" hex 17t double sprocket.
Unread 03-12-2015, 19:20
zinthorne's Avatar
AKA: Avery
I can not find the round version. Am I missing something on the website?
Unread 03-12-2015, 19:42
Greg Woelki's Avatar
Greg Woelki Greg Woelki is offline
FRC Alumnus
FRC #1768
Greg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of lightGreg Woelki is a glorious beacon of light
I emailed them about it last year. The file can be found here.
Unread 03-12-2015, 22:42
Jacob Bendicksen's Avatar
Jacob Bendicksen Jacob Bendicksen is offline
Figuring out what's next
Jacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond repute
Wait, Mean Machine's not doing swerve?
Glad to see you're having fun and building robustly for BunnyBots -- should be a fun event.
jacobbendicksen.com | @jacobbendicksen
Yale University Class of 2020
Team 1540 | 2012-2016
7 Chairman's Awards, 6 other awards, 2015 Dean's List Finalist, 1 event win, 2 finalist finishes. Thanks for an amazing ride.
Unread 04-12-2015, 17:43
Nebster's Avatar
Nebster Nebster is offline
AKA: Ben Kishter
FRC #1306 (BadgerBOTS)
Nebster is an unknown quantity at this point
What are you doing for center drop? Do the sprockets you're using inside the tube have enough clearance with the walls of the tubing for a center drop? I haven't seen that done before but since you're using 1/16" tubing it could be possible.
Do you feel 1/16" walled tubing is strong enough for a traditional drive train?
2015 Wisconsin Regional Chairman's Award - Carson Division
2013 Wisconsin Regional Chairman's Award - Curie Division
Unread 04-12-2015, 18:06
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Yep, I'm looking forward to it!
The bearing blocks we are using have their bearing holes drilled 1/16" off center. The center wheel has its block upside down compared to the outer wheels, so that gives us 0.125" drop. If it tips around too much or is too squirrely, we will flip one of the outside wheels for effectivly a 0.0625" drop. We are using 16t #25 chain sprockets.
I think so, but we'll know for sure by the end of the month.
Anything that survives this BunnBot game will certainly be "strong enough for a traditional drive train"
Unread 04-12-2015, 18:14
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
Yes, 1/16 wall tubing is easily strong enough for a drivetrain.
(2015-?): 973
(2012-2015): 955
Unread 07-12-2015, 10:45
This is not a safe general statement to make at all. There are multiple loading conditions to consider, and it entirely depends on how you build your frame, what loads it is exposed to, etc.
Generally, 1/8" wall (or .1" wall) tubing is used on the driveline in order to support the bearings or internal bearing blocks better. 1/16" is too thin for a drivetrain bearing fit not supported by anything else. So regardless of strength many teams run 1/8" wall on the driveline. This could be different for systems like the VersaBlock which don't rely on the internal walls of the tube for support.
As for your cross members, I have heard in the past that teams have dealt with buckling cross members under very heavy defense when they used 1/16" 2x1 tubing. This obviously depends on the number of crossmembers used, any other cross-structural support from other mechanisms, etc. but I wouldn't just say "1/16th is easily strong enough" as a general statement.
