Re: pic: WCD off season chassis from 2471
I can not find the round version. Am I missing something on the website?
Wait, Mean Machine's not doing swerve?
![]() Glad to see you're having fun and building robustly for BunnyBots -- should be a fun event. |
What are you doing for center drop? Do the sprockets you're using inside the tube have enough clearance with the walls of the tubing for a center drop? I haven't seen that done before but since you're using 1/16" tubing it could be possible.
Do you feel 1/16" walled tubing is strong enough for a traditional drive train? Last edited by Nebster : 04-12-2015 at 17:49. |
![]() Quote:
Anything that survives this BunnBot game will certainly be "strong enough for a traditional drive train" |
Yes, 1/16 wall tubing is easily strong enough for a drivetrain.
Generally, 1/8" wall (or .1" wall) tubing is used on the driveline in order to support the bearings or internal bearing blocks better. 1/16" is too thin for a drivetrain bearing fit not supported by anything else. So regardless of strength many teams run 1/8" wall on the driveline. This could be different for systems like the VersaBlock which don't rely on the internal walls of the tube for support. As for your cross members, I have heard in the past that teams have dealt with buckling cross members under very heavy defense when they used 1/16" 2x1 tubing. This obviously depends on the number of crossmembers used, any other cross-structural support from other mechanisms, etc. but I wouldn't just say "1/16th is easily strong enough" as a general statement. |
