Go to Post First is more than a competition it is a family. - amos229 [more]
Unread 03-12-2015, 12:09
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: paper: Analysis of “a torque-actuated module” used for strafing in an H-drive.
Is this assuming a value of θ that's fairly close to 90°? For small values of θ, it seems like assumption 1 for the B force no longer holds - the primary limitation on the normal force will come from the lever action of the module.
Here's my derivation for small values of θ:
  • Rwheel - the radius of the wheel
  • Rlever - the distance between the drive/pivot axle and the wheel axle
  • θ - angle between the drive and wheel axle, relative to horizontal
  • Rmoment - the distance between the drive axle and the contact point of the wheel on the ground
  • ρ - the gear ratio between the drive axle and the wheel axle. (driven gear teeth)/(driving gear teeth)
  • μ - coefficient of friction
  • τ - motor torque about the drive axle
  • N - normal component of the reactive force of the ground on the wheel
  • F - frictional reactive force of the ground on the wheel
  • Fmax - the maximum frictional force, μ*N using Coulomb friction
F = τ*ρ/Rwheel
Fmax = μ*N
N = τ/Rmoment*cos(θ)
Law of cosines:
Rmoment = sqrt(Rwheel^2+Rlever^2-2*Rwheel*Rlever*cos(90+θ))
= sqrt(Rwheel^2+Rlever^2+2*Rwheel*Rlever*sin(θ))
In order for the wheel not to slip, F <= Fmax
Thus, τ*ρ/Rwheel <= μ*τ/Rmoment*cos(θ)
ρ <= μ*Rwheel/Rmoment*cos(θ)
ρ <= μ*Rwheel*cos(θ)/sqrt(Rwheel^2+Rlever^2+2*Rwheel*Rlever*sin(θ))
FRC 766, 2015-, Mentor
