Go to Post We might not be as good as 217, or the other traditional "powerhouse" teams... but we are better because of them. Jason - dtengineering [more]
Unread 05-12-2015, 23:42
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: pic: Wood Coast Drive V2
Originally Posted by Mr V View Post
Yes pop rivets can be used with wood successfully. That is the way that all the angle aluminum, handles and latches are attached to the road cases that transport the fields and materials are made. Now when we made them for the PNW district we put a back up washer on them but the ones that FIRST made that I have looked at closely did not use back up washers.
It will also matter which direction you insert the rivet. You are less likely to need a back up washer if you have the mandrel/tool on the wooden side than on the metal side, though it may not look as neat if the metal is on the outside. We had this issue this week with riveting plastic to aluminum, in which this difference is probably greater.
