Go to Post "Programming is 1% talent and 99% not getting distracted by the Internet." - FRC4ME [more]
Unread 06-12-2015, 23:32
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Re: pic: Wood Coast Drive V2
Originally Posted by z_beeblebrox View Post
I added the superstructure mount. It weighs only ~3 lbs and can be tilted by removing two quick-release pins. I also moved the bumper mounts to the superstructure mount to facilitate access.
Images
Solid looking concept! Make sure the aluminum posts in the corners are mounted securely, since they'll take a big impact load when you run into stuff. How are they attached to the frame?
EDIT: just realized that the frame itself will still take the bulk of the impact loads, as the bumpers are contacting it
Also, good luck getting the bumpers on and off... the c-channel mounting hardware at the ends of the bumpers runs into your superstructure mounts in the process. Maybe just need angles instead of c-channels for those.
