Originally Posted by GeeTwo
Did you consider rivnuts or other captive nuts? When combined with a cordless screwdriver and the appropriate bit, this could be just as quick to remove and replace as a rivet -- without the shavings and need to keep a big stock of fasteners in the pit.
The problem I see is, where do you install the RivNuts in the tube to where you can still remove and replace the chassis rail internals without running into the RivNuts? If it were a rivet, you just drill out the rivet to remove the tube, which also removes the obstruction in the tube.
I walk the pits of FIM and take cool robot photos.
•Lead Driver 2009-2013 •Mechanical Mentor 2014-2015
•Record of 6-2
