Go to Post GP is a code which is lived by, not a yardstick to measure others by. - Daniel_LaFleur [more]
Unread 09-12-2015, 20:49
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: pic: 2015 Off-season Single Speed Coaxial Swerve Chassis
Originally Posted by Sh1ine View Post
... I am really impressed that the motors are stationary in this design. I feel ignorant, but what separates a swerve drive from a coaxial swerve? ...
That's the practical point of coaxial - the motor cases are stationary relative to the chassis. Coaxial swerve means that at some point, the steering bearings and the drive axle bearings have the same axis. The far more common configuration is similar to this, where the drive axle goes through the steering bearing.
Also, the wheels look to be 4" diameter, based on a 2.5" diameter CIM.
