Go to Post As far as the GDC being that mean, at least three of them have the pure evil genius rating, and the rest are simply pure evil. - EricH [more]
Unread 10-12-2015, 08:10
hectorcastillo's Avatar
hectorcastillo hectorcastillo is offline
Former Driver and Team Captain
FRC #3481 (Bronc Botz)
hectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to allhectorcastillo is a name known to all
Re: pic: It's so dense every wire has so much going on
https://drive.google.com/file/d/0B8z...ew?usp=sharing
We did something very similar this year. We mounted the RoboRio, PDP, PCM, VRM, and Pneumatic gauges and regulators on the top and motor controllers on the bottom so that the module sandwiched the wires. The result was a very clean and elegant control panel that we were able to easily remove in a couple of minutes.
A couple problems with it:
Perhaps it's not the best place to put pneumatics because getting a leak in the middle of the panel is a nightmare.
Also any time you needed to work on the wiring, you have to disassemble the thing which can get annoying after the forty-eighth time.
365 The Decontaminators (FLL) 2011 - 2012
3481 The Bronc Botz (FRC) 2012 - Present
6221 Panther Bots Alpha (FTC) 2012 - 2016
As a FIRST Alum, it's nice to be able to eat dinner again. That is, until I get off the meal plan and have to start feeding myself.
