Go to Post Andy Baker is so awsome, that his presence alone at the competition caused the scoring system to crash....multiple times...at all 8 regionals. - Andy Grady [more]
Unread 10-12-2015, 16:28
Mason_Korkowski Mason_Korkowski is offline
FRC #2169
Mason_Korkowski is an unknown quantity at this point
Re: Update to the board
Originally Posted by philso View Post
Do you intend to swing the upper board aside while all the wires to it are connected? If so, you will have to route those wires properly to make this possible. Hinged/moving electrical panels are tricky to do well.
Will the remaining screw/bolt and the corner of the upper panel take the weight of all the components and the attached wires?
It would be better to label your wire pairs and cables (PWM, CAN, sensor) at both ends. Colour coding can be used to identify wires and groups of wires with similar functions.
Yes the hinging will happen while the wires are connected. It is hard to see but there is a L shaped hole that allows for the wires to pass through. When the top board rotates on the bolt the L shape allows for extra room for the wires to shift.
As for the color coding goes the 3 wires currently that are the same are the white wires. on both ends of the wires are small colored zip ties. ex(PCM has a blue zip tie on both ends and the VRM has green zip ties)
