Go to Post People will only work toward common goals when they are part of the goal-setting process. - GaryVoshol [more]
Unread 10-12-2015, 22:11
philso philso is offline
FRC #2587
Re: Update to the board
Originally Posted by Mason_Korkowski View Post
Yes the hinging will happen while the wires are connected. It is hard to see but there is a L shaped hole that allows for the wires to pass through. When the top board rotates on the bolt the L shape allows for extra room for the wires to shift.
As for the color coding goes the 3 wires currently that are the same are the white wires. on both ends of the wires are small colored zip ties. ex(PCM has a blue zip tie on both ends and the VRM has green zip ties)
You will still have to route the wires so they do not impede the motion of the upper board. Often it takes the form of a loop.
You may want to get a label maker such as the one linked below. The wiring then becomes self documenting. They have a deal where you buy a bunch of labels and get the machine "for free". We are now using a similar machine for the equipment we build at work.
http://www.labelcity.com/Rhino-4200-...t-1835374.html
http://www.labelcity.com/Free-Dymo-L...-Purchase.html
