Go to Post The question was asked. The GDC gave their ruling. If you don't like it then maybe you can run your own tournament and let people ignore your rulings. - Daniel_LaFleur [more]
Unread 11-12-2015, 18:16
Al Skierkiewicz Al Skierkiewicz is online now
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Re: pic: It's so dense every wire has so much going on
Originally Posted by Jimmy Nichols View Post
Obviously we do not know the game rules for this year, but 1 rule that probably won't change is that all breakers and the PDP must be easily visible to inspectors. In addition their are diagnostic lights on the PDP that you would not have access too.
I don't see your Circuit breaker either, which needs to be accessible.
Everything that Jimmy has said and more.
Inspectors need to see the breakers, the wires that they feed and the color codes used. The terminals must be rated for current that exceeds the protected current for that branch (i.e. rated for 40 amps minimum when branch is protected by a 40 amp breaker). You may need to show data for those terminals during inspection.
From 2015 rules (unlikely to change much)
R40 All non-SIGNAL LEVEL wiring with a constant polarity (i.e., except for outputs of relay modules, motor controllers, or sensors) shall be color-coded along their entire length (from the manufacturer) as follows:
A. Red, yellow, white, brown, or black-with-stripe on the positive (e.g. +24VDC, +12VDC, +5VDC, etc.) connections
B. Black or blue for the common or negative side (-) of the connections.
I agree with Gary that heat is a bad thing especially when under the RoboRio.
Al
WB9UVJ
www.wildstang.org
________________________
