Go to Post Robotics is better than Football. Robotics > Football !!! - Arkorobotics [more]
Unread 12-12-2015, 20:47
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: paper: Analysis of “a torque-actuated module” used for strafing in an H-drive.
Ryan,
I think I understand your reasoning, and based on that, only disagree on one minor point:
Thus, the only forces that could generate L are reaction forces.
There is also the weight of the module, which is applied at the CoG, presumably a bit below the drive bearing when the module is horizontal, and thus will provide a slight torque about the drive bearing, and produce a bit of L in the upward/right direction. However, I have already argued that this force is negligible compared to the drive forces.
