Go to Post Q&A is certainly a good route to take, but depending on how gray the topic in question is, CD is certainly a good place to ask the question. - slijin [more]
Unread 13-12-2015, 21:33
AKA: Daniel Koh
FRC #0299 (Valkyrie Robotics)
Re: pic: 649 Offseason Hexagonal Chain-in-Tube WCD
Originally Posted by first_newbie View Post
Is this slightly better at turning due to the wheel that is on the outside (wider track width)
I think that is correct, but the main intentions of this drivetrain is to have the ability to work around t-bones.
I believe you will also be able to get a 4wd out of that system too!
Yup. However I don't see any advantages of a 4wd as opposed to a 6wd or a 8wd, and I think the reason is because how many wheels are in contact with the ground (probably 99.99% wrong because of drop center).
Also, one time I saw a 4wd FTC chassis, and when it turns the entire thing shook, and I think that was because of the rubbing of the wheels. I think if we use a 4wd on this drivetrain, we will see the same thing happen, although I am not entirely sure.
-KohKoh
115 MVRT, Driver (2013-2015)
649 M-SET, CAD (2015-2016)
