Go to Post "I don't need an anniversary party. Use the money for the kids on the robotics team."- Walter Suchowiecki, BMS technician - Wayne C. [more]
Unread 12-14-2015, 08:10 AM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: pic: 4183 Custom Machined Wheel
Originally Posted by Nathan Streeter View Post
Being a team that works with wood a tremendous amount, you probably know... but is a .5" hex sufficient for a wood drive wheel (even if it's only ~4" diameter)? I would think you'd at least want to make sure the interface didn't have slop.
I believe this is the answer (emphasis mine):
Originally Posted by GUI View Post
It is designed to mount a VersaHub to interface with a 1/2" hex shaft, and the blue nitrile tread is attached with CA glue and staples.
As I read it, the hex hole in the wood isn't for torque transfer, but presumably for alignment.
