Go to Post The only way to make a noticeable shift in OUR culture is if there are a lot of small shifts. - JVN [more]
Unread 12-15-2015, 01:02 AM
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Re: pic: 4183 Custom Machined Wheel
For BEST one year (Warp XX - 2012) we needed a large winch spool to wind up the cable we were climbing. I took the largest hole saws we had (3.5" and 3" I think) to some plywood and acquired 4 disks of wood of equal diameter and 2 larger disks for outer guards. I used a .25" pilot bit in the saw, so I aligned all 6 disks on a 1/4-20 all-thread with glue between each layer and clamped overnight. I then chucked the all-thread into the drill press using it as a lathe to sandpaper the edges smooth. It worked fantastically.
A few more steps and you could have basically this wheel on nothing more than a drill press. The hex broach is unlikely, so maybe a versa hub on both sides.
