Go to Post The robots that rise to the top will not be the ones that do everything poorly, but the ones that are breathtaking at one thing. Be that robot. - DampRobot [more]
Unread 15-12-2015, 16:52
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
pic: SPARK
Unread 15-12-2015, 16:53
JPBlacksmiths's Avatar
JPBlacksmiths JPBlacksmiths is offline
AKA: John Cashman
FRC #0806 (Brooklyn Blacksmiths)
JPBlacksmiths is an unknown quantity at this point
Re: pic: SPARK
What are the advantages of this as opposed to a talon or victor?
Unread 15-12-2015, 16:55
jkelleyrtp's Avatar
jkelleyrtp jkelleyrtp is offline
Let's just build a robot
AKA: Jon Kelley
FRC #5511 (Cortechs Robotics)
jkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of light
Re: pic: SPARK
Mainly just that they are $45 as opposed to $60 or $90. And they have more flashy lights.
Cortechs Robotics 2014-Present
Mechanical, CAD
Unread 15-12-2015, 16:59
Ernst's Avatar
Ernst Ernst is offline
Ernst
AKA: Ernst
FRC #1732 (Hilltoppers)
Ernst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond repute
Re: pic: SPARK
I'll take 20
FIRST Team 1732- Hilltopper Robotics
Website, Facebook, Twitter, Instagram
Unread 15-12-2015, 17:11
Re: pic: SPARK
My team likes the flashy lights. Especially the range of colors, which indicate whether the controller is set for BRAKE or COAST mode.
Test data made available by CTRE indicates a bit less maximum motor voltage available with the SPARK, when compared to Talons or Victors. I am not sure whether that is due to differences in on-state resistance of the FETs (Rds_on), or modulation depth, or something else.
We plan to test SPARKs at the Whirlpool motor lab soon, by the method(s) Ether developed a while ago. Will post what we find.
edit: @JPBlacksmiths (below) -- we have not seen performance differences when testing SPARKs in our test drive train (see OP). Will have to wait for bench test results before commenting on component level differences.
Richard Wallace
since 2003
Unread 15-12-2015, 17:14
AKA: John Cashman
Re: pic: SPARK
Is there any performance differences?
Unread 15-12-2015, 17:56
Sperkowsky's Avatar
Sperkowsky Sperkowsky is online now
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
We just bought 4 sparks. Now we have 4 sparks and 4 victor sps for the season. Motor controllers check.
Unread 15-12-2015, 18:34
ahartnet's Avatar
ahartnet ahartnet is offline
AKA: Andrew Hartnett
FRC #5414 (Pearadox)
ahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant future
Re: pic: SPARK
I'll add that they're cheaper, have a PWM cable retention (though I need to see it work in person to have faith in it) AND they still have an easy to use limit switch input. Limit switches are a very easy way for teams to improve their robot functionality/robustness in my opinion. It looks like the SPARK has a slight advantage over the talon in its ease of use for the limit switch sensor input since it appears you could plug a PWM cable. Many teams have PWM cables laying around and could rig it up to a limit switch. The talons require a little bit more forethought to use the limit switch, either in the adapter specifically made for it or in having a 2x5.05" header which aren't used much in FRC elsewhere.
Based what I saw from the CTRE testing, I plan on using victors for drivetrain, talon SRX's for any manipulators that require encoder feedback or are pushing motor capabilities, and SPARKs for anything else (things such as intake wheels). Looking forward to 3620s test results to see if I want to stick with that plan or not
Team 451 The Cat Attack, Student Alumni (2005)
Team 1646 Precision Guessworks, Mentor (2006-2008)
Team 2936 Gatorzillas, Mentor (2011-2014)
Team 5414 Pearadox, Mentor (2015-Present)
Unread 15-12-2015, 18:39
AustinH's Avatar
AustinH AustinH is offline
FRC #4918 (The Roboctopi)
AustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to behold
Re: pic: SPARK
Furthermore, they're available on Amazon Prime...
3826: 2013 Seattle Regional Industrial Design Award & Semi-Finalists
4918: 2014 PNW Glacier Peak District Event Rookie Inspiration Award & Quarter-Finalists, 2014 PNW Mount Vernon District Event Highest Rookie Seed Award, Rookie All Star & Semi-Finalists, 2015 PNW West Valley District Event Engineering Excellence Award & Semi-Finalists, 2015 PNW Mount Vernon District Event Semi-Finalists
Visit us on the web at www.team4918.org
Unread 15-12-2015, 19:03
s1900ahon s1900ahon is online now
AKA: Scott McMahon
FRC #2468 (Appreciate)
s1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant future
Re: pic: SPARK
2468 retrofitted our 2014 robot with Sparks; a quick and simple swap for the Talon SR. These were powering the CIMs of the drive (dual CIM VEX ball shifters). No notable problems with the students driving it "hard" and no noticeable change in driver response.
Scott
I did notice a behavioral quirk of our students.. when we have a new robot and we don't want them to over stress things too much they typically do... and when you have new-to-us motor controllers that you *do* want them to abuse, they don't. Weird.
Unread 16-12-2015, 14:10
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
lynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond repute
Send a message via AIM to lynca
Re: pic: SPARK
Nice ! no shipping costs
I hope more of the Robotics parts become available on Amazon
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 16-12-2015, 14:20
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Re: pic: SPARK
From Small Parts to Amazon... we've come full circle.
"La mejor salsa del mundo es la hambre" - Miguel de Cervantes
"The future is unwritten" - Joe Strummer
"Simplify, then add lightness" - Colin Chapman
Unread 20-12-2015, 22:47
Sperkowsky's Avatar
Motor controller breaks on practice day? Don't worry you can overnight a new one.
Unread 21-12-2015, 10:37
cad321 cad321 is offline
AKA: Brian Wagg
FRC #2386 (Trojans)
Re: pic: SPARK
Does anyone know if these will be made available to international teams? Specifically Canada? I went on amazon and their only offering shipping to the states at the moment.
Unread 21-12-2015, 13:02
REVving up for a new season
FRC #2848 (All-sparks)
Re: pic: SPARK
We are working on options for International teams right now, and will have something to announce very soon. If you want you can email us at contact [at] REVrobotics [dot] com and we will send you information when it is available.
Thanks,
Greg
Greg Needel│www.robogreg.com
