Go to Post The Championship is not always about bringing the robot...it's about learning, experiencing, and celebrating FIRST. - Jessica Boucher [more]
Unread 12-17-2015, 12:09 AM
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Mr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond repute
Re: pic: 4183 Custom Machined Wheel
188 has had a lot of experience and success with wood wheels on FRC drivetrains. Most were turned on a wood lathe, no CNC, DROs etc. They tended to be dead-axle with sprockets bolted directly to the wheel. I don't think they've ever needed to put flanges on the wheels to keep the tread in place, but I'm sure that will help. They do securely rivet or screw the tread on to the wheel. Special care is needed for the rivets at the end of the tread. It's hard to explain, but they put two rivets at the ends, but cut notches into the ends so that a half-width of the start of the tread sits beside a half-width of the end of the tread, and the ends "overlap" (not on top of each other, but beside each other). The two rivets go right beside each other, one into the start of the tread, one into the end, in the middle of the overlap. Very clean, and prevents any gaps in the tread - there's at least half-width at the gap.
