Go to Post In racing, speed is measured in cubic dollars. In FIRST, success is measured in cubic skill. - Billfred [more]
Unread 18-12-2015, 12:40
Zebra_Fact_Man's Avatar
Zebra_Fact_Man Zebra_Fact_Man is offline
]\/[ Go Blue!
AKA: Solomon
FRC #1076 (Pi Hi Samurai)
Zebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant future
Re: pic: 3946 off-season strafe module, overhead view
Is there any concern regarding the torque applied in the side-to-side direction to the hinge by the wheel/motor? Seems like there would be a little bit of pivot around that hinge that would cause material fatigue / potential failure.
Worst case scenario the piston shaft slightly bends.
My Journey in FIRST:
Mentor/Coach/Engineer
2014-2016: Team 1076 - Pi Hi Samurai
____ 2014: Team 5220 - The Rockets
2009-2014: Team 313 - The Bionic Union/Bionic Zebras
Student
2006-2009: Team 313 - The Bionic Union
Unread 18-12-2015, 13:36
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Both of these issues are being discussed at the thread on the oblique view.
The cylinder arm is mounted so that no transverse force can be applied. The hinge is a known concern, but it should be up to handling that torque; testing will tell.
Unread 18-12-2015, 13:55
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
This is neat. I like the sanded-down HiGrip wheels used as spacers to keep the belts in line.
Looking forward to your test results.
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 18-12-2015, 14:37
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
-Nick
Thanks, that's what we did for our Recycle Rush robot as well, though we removed the tread with a knife, not through sanding. Making that cut safely (mostly so the knife wasn't facing anyone) did involve a bit of creativity.
Same here. The team is taking the next two weeks off to catch up on sleep (and celebrate Christmas and New Year's and so forth), so the best chance for this to happen anytime soon is if we decide to go H-drive for some prototypes, or if we use this as a scrimmage base.
Unread 18-12-2015, 21:38
jeremylee's Avatar
jeremylee jeremylee is offline
FRC #1736 (Robot Casserole)
jeremylee is a jewel in the roughjeremylee is a jewel in the roughjeremylee is a jewel in the rough
Might be nice to mount a piece of 1x2 tube between the inner rails next to gearboxes and use the new VersaDrop module.
