Go to Post The fact of the matter comes down to this: No matter what you are interested in, you can always encourage others. - Amanda Morrison [more]
Unread 18-12-2015, 22:38
AKA: Daniel Koh
FRC #0299 (Valkyrie Robotics)
Re: pic: Versadrop Decadrive
Looks good! Really like the use of COTS parts as opposed to custom parts.
I just have a few questions...
  • What is the speed of the drivetrain?
  • Are you going to add a belly pan to the chassis?
  • Why are you using two CIMs for the strafing module? The reason I'm asking this is because I did make a similar drivetrain in the past, and I ended up using only one CIM for the strafe module.
  • Is there anyway to add a smaller diameter traction wheel? If that happens, then you have two speeds, and one could be used for a pushing match.
-KohKoh
115 MVRT, Driver (2013-2015)
649 M-SET, CAD (2015-2016)
