Go to Post I believe with every fiber of my being that Engineering is an Art. It is a beautiful, wonderful, delightful art. - Joe Johnson [more]
Unread 18-12-2015, 22:50
RoboticDaymon's Avatar
RoboticDaymon RoboticDaymon is offline
AKA: Daymon W.
FRC #2403 (Plasma Robotics)
RoboticDaymon is an unknown quantity at this point
Re: pic: Versadrop Decadrive
Originally Posted by KohKohPuffs View Post
Looks good! Really like the use of COTS parts as opposed to custom parts.
I just have a few questions...
  • What is the speed of the drivetrain?
  • Are you going to add a belly pan to the chassis?
  • Why are you using two CIMs for the strafing module? The reason I'm asking this is because I did make a similar drivetrain in the past, and I ended up using only one CIM for the strafe module.
  • Is there anyway to add a smaller diameter traction wheel? If that happens, then you have two speeds, and one could be used for a pushing match.
Speeds about 14 on omni and 7 on traction
A belly pan will probably be added in later
I have the two cims there so I have the option to have two or use a minicim or just use one. So basically its for flexibility.
The versadrop doesn't seem to play nice with different size wheels. It achieves different speeds on traction and omnis through another reduction via sprockets.
Plasma Robotics 2403 (Student 2013-2016)
CAD, Mechanical, Strategy, and Scouting
2016 - Arizona West Regional Chairman's Award
2015 - Arizona West Regional Finalists and AIA State Championship 3rd Place Alliance
2014 - Arizona Regional Winner and Engineering Inspiration Award
2013 - Las Vegas Regional Finalist and Engineering Inspiration Award
