Go to Post Seriously, I figured we had until january before we started lawyering things again. - JamesBrown [more]
Unread 21-12-2015, 16:02
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
Re: pic: Mecanum 8 inch Iso
Originally Posted by Knufire View Post
AFAIK, reusing the CAD would be illegal. I have reCADed nearly identical drive systems during build sesaon to maintain legality.
On the other hand, if the CAD is published and available to the entire community, it's legal.
See R13 from the 2015 Game Manual:
If you post the CAD files online before kickoff you should be okay. I think I remember an annual flood of CAD designs being posted in the two weeks before kickoff in order to keep the legality.
2013-2016: FRC 3175 Knight Vision, student
2014 Center Line District Finalists with 815 and 280
2016 Woodhaven District Winners with 3604 and 6116
2017-?: Rose-Hulman Institute of Technology
Unread 21-12-2015, 17:02
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
There's also a flood of syncs to teams' Github and other software source code control accounts during this period for the same reason -- sync up!
Unread 21-12-2015, 23:50
cgmv123's Avatar
cgmv123 cgmv123 is online now
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Note that we currently don't know what, if any, parts/design reuse rules are in the 2016 Game Manual.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 23-12-2015, 20:17
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
You can't be ready for every possible rule change, but that's no excuse for not being ready for rules that we expect to be carried from one year to the next with no change. I can't see the GDC deciding that designs posted publicly can be used by every team except the team that posted them; there's no exit strategy from those pitchforks.
Unread 22-12-2015, 09:13
suttonrc suttonrc is offline
FRC #3799 (Electric Fire)
suttonrc is infamous around these parts
If I recall correctly, the 2014 bumper rules required that the bumpers be backed/supported by the frame every so many inches (8?). I don't see any frame backing down the sides apart from the corners.
Good point. I left it open (in each design) as the bumper rules are a bit different from year to year. Depending on this year’s rules I could potentially mount stand offs on the side, between the rear wheel and the front motor, also potentially sideways within the chain loop or if necessary I could move everything in and put a full length member (or plate) on each side, but I would prefer not to if the rules allow it.
I hope to have the CAD posted sometime tomorrow. Am I correct in thinking that Google Drive is the standard way of doing that?
Originally Posted by LeelandS View Post
I like the design and I applaud your team's efforts to have some set designs ready for kick-off. Just remember you have to redesign the whole set-up after kick-off for it to be legal.
Just wanted to point out that when using Mecanum, you want to have an even weight distribution across all 4 wheels. It looks like most of your robot's weight is on the back wheels. This will cause your robot to strafe improperly (as if it were rotating around it's front). You can use a gyro to compensate for this rotation, but evenly spreading your weight is probably the easiest way to go.
Other than that, good job! I love all the designs you've put up.
As shown the drive base would definitely strife an arc. In the past though the mechanism, and game pieces (that we typically locate on the front) tends to involve a good amount of structure, motors, gearboxes etc. I'm thinking, picking up totes, climbing 3 rungs of a pyramid, shooting basketballs and a robotic arm to pick up inner tubes. They were all centrally located more or less in the front of the robot. The rear weight bias is intentional as in the past we've had issues falling over forward due to being too nose heavy after adding our upper structure.
Unread 22-12-2015, 09:27
Ari423's Avatar
Ari423 Ari423 is offline
FRC #5987 (Galaxia)
NO. Please post CAD files on GrabCAD so people with any (or no) CAD software can look at it without downloading huge files. Also, if you get in the habit of using GrabCAD Workbench, it automatically does version control and file sharing for you.
2017-present: Mentor FRC 5987
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
Unread 23-12-2015, 17:55
Below are links to the CAD files.
https://grabcad.com/library/mecanum-8in-wheels-1
https://grabcad.com/library/mecanum-4in-wheels-1
https://grabcad.com/library/skid-steer-2-speed-1
https://grabcad.com/library/skid-steer-1-speed-1
