Originally Posted by wmarshall11
...I'd suggest moving the piston further from the pivot or moving the dropped wheel closer. Increasing your piston bore would also be effective, and will provide a more dramatic (quadratic) effect than changing your radii.
Agreed. I had assumed that the piston was essentially over the wheel pivot, as on the VersaDrop. Looking more carefully at the render, I see that you'll only get about 60% of your cylinder force as lift. You'll have to move the cylinder and cross bar out, or increase your piston diameter by about 30%. (1.3 * 1.3 * 0.6 = 1.01)
