Go to Post I know I exaggerated a bit, but NASA put a man on the moon with less processing than some FRC bots. Think about that for a minute. - JesseK [more]
Unread 22-12-2015, 14:42
Ari423's Avatar
Ari423 Ari423 is online now
FRC #5987 (Galaxia)
Re: pic: Octocanum Module
Originally Posted by wmarshall11 View Post
Take it for what you will, but I'd suggest moving the piston further from the pivot or moving the dropped wheel closer. Increasing your piston bore would also be effective, and will provide a more dramatic (quadratic) effect than changing your radii.
Yeah I messed up my math when calculating the torque needed to lift the robot. I will probably end up increasing the cylinder to 2" diam. which should be more than enough torque even with the piston where it is. I would go for a 1.75" pancake cylinder, but Bimba doesn't offer that and they're the only pneumatic company I've ever worked with.
It's super great that you've decided to teach yourself CAD and have worked on original designs just a few weeks into it. Good for you, keep doing that.
That said, this design might need some work, and building a cantilevered octacanum module like this is a somewhat complex endeavor that is probably not the best first design project for someone new to this stuff.
The "double cantilever" of supporting a drive module cantilevering off of an already cantilevered shaft can put some weird and strong bending moments on the drive shaft that it may not be ready to support. Specifically when a robot is pushing you from the side (or to a lesser extent, when you're strafing) - there's a real danger in bending the shaft this way and you'll want to be really careful.
For "west coast" drop drive modules like this, I've always been more comfortable with a design that straddles the drive tube, rather than hanging off of it. You can add some low friction plastic blocks between the module and the frame so that if the module deflects under load, the forces are transmitted to the frame rather than the axle supporting the module, and even if the axle supporting the module takes some load, it will be on both sides of the tube very close to the side walls which is a lot better of a loading condition. The Vex drop modules do this for good reason; they are a good starting point for a design.
If you are going to face mount the piston then using it only to push the module down is the correct choice. If you couple the piston to the module but rigid mount it on one end, you put a bending moment on the piston, which is bad news bears and just unnecessary. You'll have to pivot mount the piston on both ends if you want it to provide the up-lifting force to hold the mecanum off the ground, which is a lot more of a pain than just throwing a torsion spring on there.
If you're using 1/8" plates for the module, I would just get rid of the lightening altogether. The pattern you have has a web that is too thin to do anything in the middle and it gets dangerously close to those bolt holes. The lightening saves you maybe like a quarter pound per module?
Can you make the mecanum wheel a dead axle wheel? This way you can use the axle as a structural member and you get some "free" rigidity.
Overall, a good start!
Thank you! I was originally planning on attaching the cylinder to the module, but I decided against it when I realized I would need the double hinge. When I saw that the VersaDrop doesn't have the piston attached, I thought that would be okay to do, but I forgot to add the spring return. That will definitely be something I add in the next version.
As far as the cantilevered module goes, I don't know if you saw that the module is supported by two pieces of VF Stock, not just the one shown in the render. If you take a look at the 3D model, you can see that the module is constrained on both sides. That being said, the problem of side loading is something I was keeping in mind when building it. I was under the impression that a 1/2" Hex shaft constrained on both sides would be strong enough, but I don't have any experience to prove this. If this isn't true, what do you think I could do to fix this problem?
I was wondering about the lightening. Do you think it would be better to make it a thicker plate and add pockets or leave it 1/8" plate and take out the pockets?
Since the mecanum wheel is AndyMark and the pulley is Vex, there's no easy way to attach them and make it a dead axle. Sadly, AndyMark doesn't make an 18t pulley and Vex's 4" mecanum wheel doesn't support dead-axle drive. If you have another way to do this dead-axle, I would be interested in hearing about it.
2017-present: Mentor FRC 5987
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
Unread 22-12-2015, 15:31
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
You shouldn't need 2" - Bimba does have 1.5" cylinders in both square and round pancake styles. Remember that force goes up as the square of the diameter, so 1.5" provides twice the force of a 1.0625" cylinder (to within 1%).
You could pivot on the mecanum, which would make the cantilevered wheel the traction wheel which has a 42 tooth sprocket, if I did my math correctly. This would be easy to mount sprocket to wheel on a dead axle. This solution would also require a change in gear ratio of your gearbox - in the direction that it will probably get simpler and lighter. This would also make high-speed mecanum your "default" drive if the pressure goes out, which may be a good or bad thing depending on your game strategy/style.
Unread 22-12-2015, 15:49
Ari423's Avatar
FRC #5987 (Galaxia)
I knew I didn't need a 2" cylinder, but it was the smallest I was able to find that would work when I posted. But speak and it shall be so. I went back and checked, and this time I found the 1.5" pancake cylinder. I will probably end up using that one.
One of the big perks of octocanum for me is built-in mecanum suspension. I wanted to pivot on the traction wheel so we wouldn't have to worry about uneven loading. I agree that switching them would make it easy to do a dead axle, but that would take away a major advantage in my opinion. Would it be advantageous to add more bolts, a piece of churro, or some other cross brace between the wheels to better connect the plates instead of going to dead axle?
2013: Programmer
Unread 22-12-2015, 16:20
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
I don't see how the air suspension would compensate for uneven loading. Air (especially if allowed to flow among the cylinders, or vent when over-pressured) does not behave like springs do in this case. If you have uneven loading such that the weight on any one wheel is greater than what the air can carry, that one will drop until the traction wheels touch the carpet and compensate. At lesser inequality I believe it will lift the lightest corner relative to the others, but if you have a low CoG it will take a lot of lift to effectively move the robot's CoG to the geometric center and equalize the weight carried by each wheel.
Unread 22-12-2015, 16:25
Ari423's Avatar
FRC #5987 (Galaxia)
I was under the impression that if the mecanums were pneumatically actuated, you could tune the pressure so that the cylinders would have some give. Then the heavier wheels would compress the springs, and all four wheels would still have the same ground contact. Am I wrong?
2013: Programmer
Unread 22-12-2015, 16:51
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Based on my dry-erase figuring (not experience), the air suspension will help keep all four wheels on the floor/carpet as you go over minor bumps and dips. It will not do much to equalize the weight carried by each wheel due to differences between center of gravity and center of geometry.
Unread 22-12-2015, 16:56
Hugh Meyer's Avatar
Hugh Meyer Hugh Meyer is offline
FRC #1741 (Red Alert Robotics)
Hugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud of
Yes, you are correct. If you supply air to all four wheels and adjust the pressure so the cylinders are not bottomed out all four wheels will maintain equal pressure and contact with the ground as the system travels over uneven surfaces. This is indeed a great feature of your design. This helps steering because if one wheel floats, as a ridged system would, the robot will not steer correctly.
You may need to pivot the cylinder to compensate for the radius as the assembly articulates. Otherwise it will likely jam.
Keep up the great work!
-Hugh
Unread 22-12-2015, 20:43
This is a really bad idea from a durability perspective. If you make the traction wheel the pivoting wheel, you will have to deal with a lot more sideways loading on the module than if a wheel with rollers is the pivoting wheel. This has been a documented problem in other drop drives (e.g. 148's 2010 drivetrain) and isn't recommended if you don't have a really robust way to deal with the side loading.
Unread 22-12-2015, 20:52
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
With omnis, I would agree with you. However, mecanums generate as much side force as forward/reverse force by design even when the robot is driving directly forward. With octanum, I'd consider the traction wheels as having less sideways loading under most conditions, probably only exceeding the peak mecanum side load when being T-boned. And in that case, the solution is to switch to mecanum and strafe your way out of the t-bone, or at worst into a legal pin that (under most years' rules) is time limited.
Unread 22-12-2015, 21:34
First things first, if your solution to a design problem is to drive around the failure mode, that's just plain bad design. You should never have a robot designed in a mechanically weak manner just because the driver "shouldn't" have the robot in that mode when you expect damage. You can't bet your drivetrain on perfect play.
The strafing force a mecanum wheel puts on the robot is very different than the force of being pushed to the side in traction mode. When being pushed in traction mode, the full weight of the robot resists motion until static friction is broken. When strafing in omni / mecanum mode, there is no such resistance - the wheels are rotating and the rollers are allowing the motion to happen.
Finally, while you are technically right that mecanum wheels exert as much force in the sideways direction as they do in the forward / back direction, it is worth noting that this is ~70% of the peak force a traction wheel of the same gearing would put in the forward direction, assuming the same CoF for both wheels (which is also not true, all commercially available mecanum wheels have a lower effective CoF than most high traction wheels).
It is simply more robust to put the omni wheel on the pivot and the traciton wheel at the axle.
Unread 22-12-2015, 22:25
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Again, no argument as stated, but Mecanum ain't Omni.
I wasn't so much betting on perfect play, as planning on the play I've seen (which has not included t-boning, for the record). Once T-boning was under consideration based on evidence of others, the defense is straightforward. Training for this situation would be included in driver practice, not left as something that we hope the driver would invent on the spot. In any case, we would design to handle the (externally applied) strafe forces of the worst case we expect to see. If 1/8", there would likely be no pocketing. If 1/4", there would probably still be minimal or no pocketing. As I've stated before: Due to our limited machining capability, our team's general strategy is to select material for our robot, not engineer it.
Our team is not planning for an octanum drive train, but if we did, we'd be at least as likely to have the mecanums as the "fast default" and the traction wheels as the "shifted shoving" state as any of the other three possibilities.
Also, as a final fallback, we'd design any "quad-drop" drive train to have predictable behavior should the modules be pushed by extreme strafe forces. It might involve a drive shaft pushing against a plate with unreasonable friction, but the outcome would still result in a fairly reasonable, predictable outcome.
Unread 22-12-2015, 22:39
Ari423's Avatar
FRC #5987 (Galaxia)
So what I'm hearing is either configuration (mecanum or traction wheels pivoting) will have sideways forces that need to be dealt with. For traction, the big problem is T-boning. For mecanum, the problem is the constant force being applied at a 45* angle. Can anyone comment on whether they think both the 1/2" Hex shaft and the 1/8" plates (without pocketing) would be strong enough to stand up to either of these forces?
2013: Programmer
Unread 23-12-2015, 08:35
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
It's not the constant force of the mecanum or of a T-Bone. I'd be worried about that initial shock load when someone slams into your(2014) and you have pivoted the traction wheels down. You can only react so fast and you're not going to see every robot coming.
Unread 23-12-2015, 11:04
Electronica1's Avatar
Former Design and CAD Captain
AKA: Alexander Kaplan
FRC #1086 (Blue Cheese)
Honestly, we never had an issue with it. Heck, only time we had down time was when fasteners backed out into the frame (and yet we still won matches at an offseason just using it as a brake). In my experience, it is better to have the suspension on the traction wheels since then you don't loose contact with the ground when pushing, while having suspension doesn't fix a cg out of place. In addition to that, it seems that having the mecanum wheel on the end of the pivot is worse for survivability than a traction wheel that is only in use rarely. Plus, you should make the traction wheel as small as possible to cut down on weight by making the overall module smaller.
Unread 23-12-2015, 11:09
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Smaller wheels would also have the side effect of making that moment arm shorter. Reducing the torque is probably even more important than weight savings.
