Go to Post And Dave...should I borrow someone's hair dryer from here in case the NASA truck needs some de-icing again this year? - Billfred [more]
Unread 22-12-2015, 16:20
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: pic: Octocanum Module
Originally Posted by Ari423 View Post
One of the big perks of octocanum for me is built-in mecanum suspension. I wanted to pivot on the traction wheel so we wouldn't have to worry about uneven loading.
I don't see how the air suspension would compensate for uneven loading. Air (especially if allowed to flow among the cylinders, or vent when over-pressured) does not behave like springs do in this case. If you have uneven loading such that the weight on any one wheel is greater than what the air can carry, that one will drop until the traction wheels touch the carpet and compensate. At lesser inequality I believe it will lift the lightest corner relative to the others, but if you have a low CoG it will take a lot of lift to effectively move the robot's CoG to the geometric center and equalize the weight carried by each wheel.
Unread 22-12-2015, 16:25
Ari423's Avatar
Ari423 Ari423 is online now
FRC #5987 (Galaxia)
I was under the impression that if the mecanums were pneumatically actuated, you could tune the pressure so that the cylinders would have some give. Then the heavier wheels would compress the springs, and all four wheels would still have the same ground contact. Am I wrong?
2017-present: Mentor FRC 5987
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
Unread 22-12-2015, 16:51
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Based on my dry-erase figuring (not experience), the air suspension will help keep all four wheels on the floor/carpet as you go over minor bumps and dips. It will not do much to equalize the weight carried by each wheel due to differences between center of gravity and center of geometry.
Unread 22-12-2015, 16:56
Hugh Meyer's Avatar
Hugh Meyer Hugh Meyer is offline
FRC #1741 (Red Alert Robotics)
Hugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud of
Yes, you are correct. If you supply air to all four wheels and adjust the pressure so the cylinders are not bottomed out all four wheels will maintain equal pressure and contact with the ground as the system travels over uneven surfaces. This is indeed a great feature of your design. This helps steering because if one wheel floats, as a ridged system would, the robot will not steer correctly.
You may need to pivot the cylinder to compensate for the radius as the assembly articulates. Otherwise it will likely jam.
Keep up the great work!
-Hugh
