Re: pic: Recycle Rush Re-design
If I wanted to aim for the opening in the lid, how would one physically make that sort of geometry? It's not like one can bend carbon fiber to meet its needs (or can you?). Would the solution here be to use like 1x1 box tubing with the appropriate angle brackets? Or is there some better solution? Last edited by KohKohPuffs : 22-12-2015 at 22:50. Reason: grammar |
I have seen videos of 971 doing their own carbon fiber layup. It seems tedious, so you could just use 3d printed or custom made endcaps for regular CF tubes and just stick the hook on the end like that.
Nice job!
About picking up the can. - Is there a 2nd elevator section hiding behind the stack? - How does the robot grab the bottom of the can? (elevator pivot or another mechanism) Dave |
To answer the second question, the robot has a four-bar linkage arm powered by 2 BAG motors (okay is there like a thread about BAGs vs. 775s somewhere?). That lowers down and actuates a pneumatic claw to grab the bin. I do not need a pivot for the claw, because the geometry of the four-bar automatically controls the angle of the claw to be horizontal with the ground. |
Interesting.
Check out team 4488. They have an amazing robot! https://www.youtube.com/watch?v=VpZazV3wP1s Dave |
#10
What is the gear reduction for the versaplanetary on the BAGs driving the can grabbers?
#11
You might consider lifting a little higher so you can do co-op.
#12
The intake rollers also appear to be at a constant altitude and possibly location, interfering with the coop score. The rollers would need to move out of the way (or better, up so that they push the totes out). Edits: Quote:
Also, I was curious about the RC lift - do I understand correctly that it would be a two-step process to cap a stack of fewer than six totes? That is, you'd have to score the short stack, then back up a bit to score the RC atop it. Not a showstopper, but an interesting trade-off. Last edited by GeeTwo : 23-12-2015 at 11:22. |
#13
The intake rollers do actuate out - it's hard to see from the render but there is a pneumatic piston there.
#14
As for dropping a stack less than 6 totes, yes the bot does have to back up a little because of the bin grabber arm. It's a disadvantage, but I kind of also wanted to do such a mechanism because I never made such things in CAD before, and I wanted to try it out. |
#15
a 6' arm versus a 5' arm w/ all other variables held constant will have substantially less inertia, which allows higher accelerations for same power. |
