Go to Post I would feel more comfortable if you used rock-paper-scissor-lizard-Spock. - IndySam [more]
Unread 22-12-2015, 22:18
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
pic: Team 4592 Ball Shifting Gearbox - Optimized for Half Field
Unread 22-12-2015, 22:20
AKA: Ahad Bawany
no team (None)
Re: pic: Team 4592 Ball Shifting Gearbox - Optimized for Half Field
Speces:
Reduction Ratio: 12:70
High: 50:44
Low: 34:60
High Speed (adjusted): 14.6 Ft/s
Low Speed (adjusted): 7.29 Ft/s
Weight: Approx 2.3 Lbs
This is my second ever shifting gearbox. This was designed with a field with obstacles in mind, like 2012 or 2004.
EDIT: PM me for STEP files.
EDIT 2: The gearbox can also hold a 14:68 ratio to give it the following speeds
High:14.62
Low: 7.29
Unread 22-12-2015, 23:16
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
Looks like you're going for 6 CIMs. I'd recommend looking into the RoboRIO's response to voltage drops and determine if 6-cim is worth it.
Unread 22-12-2015, 23:24
AKA: Ahad Bawany
no team (None)
We would most likely mount 2 cims and a mini cim due to the brown out voltage of the roboRIO. You can read about some of the measures we plan to take to avoid brown-outs in the thread for the other gearbox: http://www.chiefdelphi.com/forums/sh...hreadid=140537
