Go to Post Wow, I am beginning to feel like a member of the fabled "vast right-wing conspiracy" :) - Jim Zondag [more]
Unread 23-12-2015, 02:13
DaveL DaveL is offline
FRC #2976
Re: pic: Recycle Rush Re-design
Nice job!
About picking up the can.
- Is there a 2nd elevator section hiding behind the stack?
- How does the robot grab the bottom of the can?
(elevator pivot or another mechanism)
Dave
Unread 23-12-2015, 02:48
AKA: Daniel Koh
FRC #0299 (Valkyrie Robotics)
Originally Posted by DaveL View Post
Nice job!
Dave
Nope, there's only one elevator, and that's exclusive to stacking. Also, the elevator is really short: it can lift up to the second tote level; after all, stacking really only occurs at that level.
To answer the second question, the robot has a four-bar linkage arm powered by 2 BAG motors (okay is there like a thread about BAGs vs. 775s somewhere?). That lowers down and actuates a pneumatic claw to grab the bin. I do not need a pivot for the claw, because the geometry of the four-bar automatically controls the angle of the claw to be horizontal with the ground.
-KohKoh
115 MVRT, Driver (2013-2015)
649 M-SET, CAD (2015-2016)
Unread 23-12-2015, 07:53
FRC #2976
Interesting.
Check out team 4488. They have an amazing robot!
https://www.youtube.com/watch?v=VpZazV3wP1s
Dave
Unread 23-12-2015, 09:04
EmileH's Avatar
EmileH EmileH is offline
it's not a water game, ok?
AKA: Emile Hamwey
FRC #1058 (PVC Pirates) & FF (NE Way You Want It)
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
What is the gear reduction for the versaplanetary on the BAGs driving the can grabbers?
Unread 23-12-2015, 09:33
nuclearnerd's Avatar
AKA: Brendan Simons
FRC #5406 (Celt-X)
You might consider lifting a little higher so you can do co-op.
Unread 23-12-2015, 10:11
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
I haven't looked at the CAD, but from the render, it appears you need more than just lifting higher to score co-op. The elevator bracket appears to be fixed on the horizontal axis, and the way it supports a tote means that it cannot be extended outside of the robot frame. This could probably be enabled without additional actuators but would certainly require greater complexity to push the totes out while being supported by the elevator.
The intake rollers also appear to be at a constant altitude and possibly location, interfering with the coop score. The rollers would need to move out of the way (or better, up so that they push the totes out).
Edits:
Originally Posted by EmileH View Post
The intake rollers do actuate out - it's hard to see from the render but there is a pneumatic piston there.
Oh, I see that now. That does mean that (as currently mounted) they would not be useful to help place the elevated stack on the step; another mechanism would be required.
Also, I was curious about the RC lift - do I understand correctly that it would be a two-step process to cap a stack of fewer than six totes? That is, you'd have to score the short stack, then back up a bit to score the RC atop it. Not a showstopper, but an interesting trade-off.
Unread 23-12-2015, 10:54
EmileH's Avatar
AKA: Emile Hamwey
Unread 23-12-2015, 22:02
AKA: Daniel Koh
Yes, there are pistons that actuate the intakes in and out. As for the bot's ability to do coopertition, I never intended this to have that function. Maybe the intakes are high enough to do it, and if it does, then I can use the intakes to roll the yellow totes out. However, for this bot it's all about the stacking. If this were in a competition, I would love the 40 points from the yellow totes, but making consistent stacks looks better for scouting. That was my logic for that.
As for dropping a stack less than 6 totes, yes the bot does have to back up a little because of the bin grabber arm. It's a disadvantage, but I kind of also wanted to do such a mechanism because I never made such things in CAD before, and I wanted to try it out.
-KohKoh
Unread 23-12-2015, 22:29
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Noted, and respected. Just trying to clarify the decisions that led to this design.
Again, noted and respected; just clarifying.
