Go to Post It's still not about the robots. FIRST is about doing the right thing. - DonRotolo [more]
Unread 23-12-2015, 11:23
philso philso is offline
FRC #2587
Re: pic: Octocanum Module
Originally Posted by Chak View Post
I notice that you have an extra bearing on the end of the traction wheel shaft. What is it for?
For the bracket that holds the piston: one side is attached to the frame, what's the other side attached to?
Is there a frame element in the foreground, running parallel to the 2 x 1 tube that you have hidden?
It looks like you have only two thin standoffs tying the two plates of the octanum module together. They may "twist" relative to one another as forces are applied to the module. The plates look pretty thin which may make this worse. If they are really thin, the pocketing will not save you a worthwhile amount of weight. If you are going to pocket the module plates, radius the corners (with larger radii near the standoffs). In 2014, we used 1/8" plate. I seem to recall that they did bend a bit after a number of hard hits from the side so you may want to make sure they don't bind on the frame if this happens.
You may also want to consider how the modules will be assembled and how you would service them, say to change a wheel. Do they have to be assembled in the frame? Our 2014 modules took over an hour to assemble, each. It may be best to investigate how 148 designed theirs. They could assemble theirs outside the robot and swap one complete module for another in just a few minutes by removing one or two bolts. You and your team mates would be much happier working on a design more like 148's than ours.
