Re: pic: Recycle Rush Re-design Part 2
Originally Posted by Cash4587
Please keep in mind that on most powered feeder stackers, the voltage drop is pretty significant over 25ft of tether. I can't speak for 148, but for my team and 1296 (if I am not mistaking), we had to use 10ga wire to get enough voltage. We also had to go with a 25:1 on a cim motor to be able to lift totes 4 totes fast enough with enough power.
Oh right, when I was in 115, we started out with one 775 and I believe a 1:100 reduction, and that was barely able to lift up 6 stacks. Although I calculated my scenario to do the job in 3 seconds (the main bot stacks much faster).
As for voltage... I never considered that actually  . If it's a 10 gauge wire it's going to be bulky... and that means more weight. I guess I can remove the can burglars if I'm going to add this with the main bot.
-KohKoh
115 MVRT, Driver (2013-2015)
649 M-SET, CAD (2015-2016)
