Go to Post The battery needs to be velcro-ed, strapped, buckled, tied, bolted, glued, zipped, or stapled in place so that it can't fall out when (not if) the robot turns upside-down. - dlavery [more]
Unread 26-12-2015, 23:31
Re: pic: Recycle Rush Re-design Part 2
Originally Posted by Cash4587 View Post
If using only pneumatics for a thethered robot you will probably need more air tanks than it is worth to try to reduce the losses from long runs of wire. Lifting a tote with pistons requires a lot of air because of the weight of the totes in addition to the amount of stroke needed to lift them high enough. To stack at the feeder station you need to lift them considerably higher than the usual of about 13-14"
If designed properly, perhaps 16" would be enough. As long as the bottom tote just sits at the bottom and you only lift totes 2-6, you just need it to clear the chute- which is doable with 13-14" if you raise the bottom tote a bit, or just 16"ish.
