Go to Post "Greatness isn't achieved by doing the uncommon things but instead by doing the common things uncommonly well." - Wayne C. [more]
Unread 28-12-2015, 14:13
Ari423's Avatar
Ari423 Ari423 is offline
FRC #5987 (Galaxia)
Re: pic: Recycle Rush Re-design Part 2
You definitely either have too much friction, or you have the wrong flow control valve installed. This is a great application for one-way flow control valves, which restrict air going in but not out. My team had a stacking mechanism that would quickly and easily lower itself even without the weight of any totes on it; unless you have an extremely inefficient system this should work fine.
I can't quite speak for the mechanical aspect of the system, as I had no hand in that. I only worked on the control aspect of the system. And since I'm the only member of my team on CD, I don't expect we'll ever get a good answer as to why our system had so much friction.
I was under the impression that one-way valves were illegal. Is that not true?
2017-present: Mentor FRC 5987
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
