Re: pic: Chain and Wheel in Tube
Bolt sprocket to wheel. Stick big bolt through spacer, sprocket/wheel/bearing setup, apply locknut/jamnut/other locking fastener. Done. (Or, use a length of steel rod from McMaster, thread the ends with a die or drill for a cotterpin. Still a minimum-machining job.)
A live axle requires a keyway/hex feature and some sort of retention for the wheel/sprocket separate fro each other. |
I'm a Software Engineer not a Mechanical Engineer so these are serious questions. |
There's also the option of throwing a tensioner block into the system, probably an off-center mounted delrin cylinder, but that kind of defeats the purpose of "ease of maintenance". |
To be quite honest, that doesn't make the machining any easier.. The way my team does it, which is not the best way to do it but is perfectly fine for FRC requires the same amount of machining. In 2014 we were able to do a c-c belt drive train on a manual mill with no issue. It used the same bearing setup as shown in this picture. Either way, it would be a bit on the mill properly spaced the correct distance from the last hole. We use a 1.125" mill bit to drill bearing holes and have had no issue with tolerance thus far, we do not us a CNC.
We have a mill with a digital read out it's pretty useful. I think the best thing about c-c drivetrains is the fact that you don't have to mill slots for bearing blocks. However, with all of the new vex/wcp parts now pretty widely available, adding tensioning cams to the drivetrain only requires one more hole drilled in the tube. the WCP bearing blocks are huge time savers.
Inside a 2" tall x 1/8" wall extrusion, this kind of chain retention only happens when using 17t sprockets. 2363 uses 16t sprockets. There are different reasons why our chains don't come off the sprockets.
#10
My point was not that all chain-in-tube has close-fit sprockets (the one pictured in OP is not), but that this technique could be exploited with a dead axle to make even "tape measure and drill press" tolerances feasible.
#11
Nothing about a dead axle drivetrain lowers the position tolerance requirement for an exact-center drivetrain at all. I have no idea what you're talking about here. You need more precision than that regardless of whether or not your axle spins.
#12
Matt,
Having worked through a problem with this design with a team at Championship a few years ago (it did not go well), I can only give you a few words of caution. It is essential that you provide for chain stretch. Chain stretches and it only takes a small amount to jump up during operation and lock the drive against the inside of the tube. The second is a restating a post I made just a few weeks ago. If you want to win on Einstein, don't design something that can't be fixed in a few minutes with simple tools in near dark conditions. Good Luck! |
#13
