Go to Post In my 30 year career, one thing I have learned is that if you truly enjoy your work, you'll be good at it. - DonRotolo [more]
Unread 28-12-2015, 18:09
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: pic: Recycle Rush Re-design Part 2
Originally Posted by Ari423 View Post
I was under the impression that one-way valves were illegal. Is that not true?
In 2015, Rule R66 F allows (among other things) flow control valves as pneumatic components. Festo's page of one-way flow control valves describes the same thing Chris is describing - allowing free air flow one direction, throttled flow the other. There does not seem to be a rule allowing check valves, which allow air to travel in one direction but completely prevent airflow in the other direction. Apart from the interface between an external compressor and the robot, it is difficult to come up with an application for a check valve that complies with 2015's rule R78, which has been a game rule for some time:
Originally Posted by 2015 Game Manual
R78 Any pressure vent plug must be:
  • A. connected to the pneumatic circuit such that, when manually operated, it will vent to the atmosphere to relieve all stored pressure in a reasonable amount of time, and
  • B. placed on the ROBOT so that it is visible and easily accessible.
If the compressor is not used on the ROBOT, then an additional pressure vent plug must be connected to the high-pressure portion of the pneumatic circuit off-board the ROBOT with the compressor (see R68).
