Go to Post Real projects have good and bad aspects, problems that must be dealt with, and lots of things that dont make any sense from your side of the fence. - KenWittlief [more]
Unread 31-12-2015, 13:19
Aren Siekmeier's Avatar
on walkabout
Re: pic: Inverted CIM Gearbox V3
Originally Posted by Cash4587 View Post
That wouldn't fix the fact that it is still cantilevered. There would need to be a supporting plate on the other side of the gear to reduce the kinds of loads a cantilevered gear sees vs a non cantilevered one.
It would reduce the torsional load on the bearing to nearly zero. A dead shaft rigidly mounted to the gearbox plate can handle high loads that are cantilevered half an inch or less. The bearing moves to the same plane as the gear, much like the gears engaged by the dog/balls in the shifting stage.
