Go to Post push for what you think is right... just do it in the right way - Andy Baker [more]
Unread 01-01-2016, 18:04
Adolfo Apolloni Adolfo Apolloni is offline
FRC #1540 (The Flaming Chickens)
Adolfo Apolloni is an unknown quantity at this point
pic: 1540's new 3 cim dog shifting gearbox
Unread 01-01-2016, 18:06
Re: pic: 1540's new 3 cim dog shifting gearbox
Looks good, reminds me of some of the low-profile shifters I've seen on here.
The way you've done the lightening pattern seems nontraditional. I think if you added a few more struts you could greatly increase the strength of the gearbox.
What cylinder are you using to shift?
That low speed seems fine for 3 CIMs, but do you have a plan for if you brown out?
EDIT: Are the gearbox plates flippable? Interesting, I haven't seen that feature before.
Unread 01-01-2016, 18:12
Ari423's Avatar
Ari423 Ari423 is online now
FRC #5987 (Galaxia)
How are you planning on attaching the gearbox to a chassis?
2017-present: Mentor FRC 5987
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
Unread 01-01-2016, 19:14
Munchskull's Avatar
Munchskull Munchskull is offline
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Looks good. Obligatory warning: The roborio is at risk if browning out from the current load and subsequent voltage drop of a 6 CIM drive train.
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 01-01-2016, 20:11
We ran bolts through the tubed took of our frame and then through the bottom 4 standoffs of the transmission. While this cantilevered the gearbox a bit, we found that with 4 bolts, that attachment technique worked just fine on one of our off season robots.
The gearbox plates are flipable.
We used .5 inch stroke, .75 inch diameter bimba button cylinders for shifting.
As for brownouts, we found that they only occurred when we were in high gear and we plan to add software base current limiting in the future to account for this.
Unread 01-01-2016, 20:48
Chak Chak is online now
AKA: Thomas
FRC #4159 (Cardinalbotics)
Why did your team decide that this is necessary? If the flipable gearbox plates is not a requirement, you can save material and space by cutting out or lightening the corner of the gearbox that doesn't have a shaft in it.
Unread 01-01-2016, 21:25
Dunngeon Dunngeon is offline
Pumped
AKA: Ryan
Dunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond reputeDunngeon has a reputation beyond repute
Under what types of testing scenarios? How much did the robot weigh/battery condition?
(2015-?): 973
(2012-2015): 955
Unread 02-01-2016, 00:16
The robot with a battery and bumpers weighed about 120 pounds. We were using 1 battery per match and we were using batteries that were purchased at the beginning of the 2014 and 2015 seasons. We tested this robot in the off-season competition called bunnybot that team 1540 hosts in December.
As for the flipable plates, we kept the section in the bottom corner so we had the ability to add a power takeoff if we wanted to later. It is an inconvenient spot for a power takeoff as it is on the bottom of the gearbox but we thought is was better than nothing.
Here is a link to a step file of the gearbox.
https://drive.google.com/file/d/0B40...ew?usp=sharing
Unread 02-01-2016, 02:02
Munchskull's Avatar
What about other mechanisms, what were their power draws?
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 02-01-2016, 11:14
I don't know exactly how much current the other mechanisms drew but we did have a football shooter driven by 2 cims and a football intake that was driven by a bag motor on that robot
