Go to Post Go with a Big Block. The torque is awesome and you cant beat the sound of a built Big Block with a high lift cam and some open headers. A blower would be a nice addition as well. Good luck getting past the inspector. - GBK [more]
Unread 02-01-2016, 21:31
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: pic: Vex Face Bearing Gusset Gearbox
Originally Posted by Ari423 View Post
It looks like the two pieces VersaFrame still need to be precision machined for the gears to mesh well. Am I wrong? If not, how is this any different from any other custom gearbox?
EDIT: How are the CIMs attached to the top piece of VersaFrame? There are holes through the gusset plates, but I don't see anything through the VF itself. Is the plan just to mount the CIMs to the gussets?
EDIT 2: Is there any reason why the first reduction has to also sum to 84 teeth, or can that be any gear ratio provided you use the right C2C distance?
There is no "top piece of VersaFrame" - the assembly above the single tube of VF is apparently composed of Bearing Gussets riveted together.
