Go to Post The way things generally work in cases like this is simple: if you know something, you can't say it. So keep in mind that if someone does say something, it usually means they don't know. - Alan Anderson [more]
Unread 03-01-2016, 01:05
aldaeron aldaeron is offline
AKA: -matto-
FRC #1410 (Kraken)
aldaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond repute
Re: pic: Vex Face Bearing Gusset Gearbox
That's even more disturbing than what I thought I was looking at earlier, which was disturbing enough. What's the point of doing a VersaFrame "gearbox" with exposed gears if you have to cut out that many rectangular holes to allow gears to reach outside of the tube? For me at least, the answer is emphatically none.
I never said this was a particularly efficient way of making a gearbox. It does involve a lot of cutting and drilling and clamping. If you want easy, buy something off the shelf - there is a lot of good stuff out there. I have a lot of younger students who LOVE clamping and drilling with the drill press.
The intention is for teams without access to a CNC to be able to make "custom" gearboxes. This is primarily an idea for my team - we used to have access to a CNC mill via a local makerspace, but it went out of business. Students used to enjoy designing and fabricating the gearboxes themselves. By "custom" I mean that the students can design the gearbox and select from more gear ratios than what Vexpro, AM and WCP offer as COTS. And if they make a mistake or are unhappy with the first iterations, the gears can be swapped.
