Go to Post I don't like to tempt the gods of inspection on items like this. - MrRoboSteve [more]
Unread 06-01-2016, 16:58
Jack S.'s Avatar
Jack S. Jack S. is offline
FRC #0624 (CRyptonite)
Jack S. has much to be proud ofJack S. has much to be proud ofJack S. has much to be proud ofJack S. has much to be proud ofJack S. has much to be proud ofJack S. has much to be proud ofJack S. has much to be proud ofJack S. has much to be proud ofJack S. has much to be proud of
Re: pic: Team 624 2015 Offseason Tesbed
Originally Posted by philso View Post
Alternatively, you can install all your electrical components on a thin polycarbonate panel then attach the panel to the pan.
This is the approach we used with the testbed. However, I would have preferred to design the pan based on the electronics layout like you suggested, but we were in a time crunch. If we use a belly pan this season (I hope to, but in my memory I don't believe we ever have), we will most likely trim down the weight and base it off the electronics layout.
2013: 1539 Clover Robotics
2014-2016: 624 CRyptonite
