Go to Post Learn the theory in the classroom and pick up the practical through clubs (FIRST, mini Baja, SAE)... you really need the scale balanced in the middle - Greg Needel [more]
Unread 07-01-2016, 08:48
jnicho15's Avatar
jnicho15 jnicho15 is offline
AKA: Dan
FRC #0548 (Robostangs)
Team Role: Electrical
jnicho15 is just really nicejnicho15 is just really nicejnicho15 is just really nicejnicho15 is just really nice
Re: pic: 2996 Octocanum Prototype
What was your reason for putting the traction wheels on the pivot? In my team's design, we placed the mecanums on the pivot because then, when you retract the traction wheels, you don't need as much cylinder force to hold them off the ground. For traction mode, the mecanums barely need to be off the ground or can be slightly touching- the cylinders don't need to support nearly as much weight. In your design, the cylinders need to hold the whole weight of the robot up off the ground so only the mecanums are touching.
2014: MIHOW DCA, Finalist
2015: MISOU Finalist; MILIV DCA, Winner; MIBED Winner; MICMP Winner, Engineering Excellence
2016: MISOU KPCB Entrepreneurship Award; MILIV DCA; MICMP 16th Alliance- 8-F winner
