Go to Post ...Well also I'm just hooked on FIRST. (I swear, I can quit whenever I want!) - CENTURION [more]
Unread 07-01-2016, 17:02
Thad House Thad House is online now
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Thad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond repute
Re: paper: Apalrd's Choo-Choo Analysis Spreadsheet
I definitely like how the launcher can be held fully cocked with little torque required from the motor; probably little enough to let the gearbox hold it (especially if that last 12:1 reduction is through a worm gear).
Is the driven axle assumed to be located midway between the "pivot" and the "pin" mounted to the disc? Have different axle locations been investigated?
If the axle was not in the line between the pivot and the pin (below this line when horizontal), it appears that the two drive periods would overlap and merge into a single steadier pull, at the cost of introducing a null sector at the opposite part of the cycle.
You can also use something like a ratcheting wrench to be an anti backdrive. Unless you want to be able to slowly release, the choo choo only ever needs to rotate in 1 direction.
All statements made are my own and not the feelings of any of my affiliated teams.
Teams 1510 and 2898 - Student 2010-2012
Team 4488 - Mentor 2013-2016
Co-developer of RobotDotNet, a .NET port of the WPILib.
