Go to Post a determined team can accomplish miracles. - Wayne C. [more]
Unread 08-01-2016, 19:51
Jay Burnett Jay Burnett is offline
FRC #5332 (Toaster Tech)
Jay Burnett is an unknown quantity at this point
pic: Toaster Tech 5332 Potential 2016 Drivetrain
Unread 08-01-2016, 19:54
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Re: pic: Toaster Tech 5332 Potential 2016 Drivetrain
Great work! I would be hesitant to have unpowered corner wheels on a drivetrain, especially one with no center drop. If there is any concavity in the field, or you get tipped back slightly, you would completely lose all of your driving ability and be stranded until something else moves you into a better spot.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
I might be slightly crazy but the gearboxes look like they're at a slight angle to me.
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
If you get pushed back at an angle, you won't have any driven wheels touching the ground.
Also, your non-driven wheels are reducing the normal force on your driven wheels, reducing traction.
Unread 08-01-2016, 19:59
I used the perspective view in Inventor to generate this render, so that effect makes it look a bit weird. They're not actually angled
That's a good point. How far would you suggest raising the omnis to fix this?
Unread 08-01-2016, 20:00
AKA: Ahad Bawany
no team (None)
Ok .
You want to look into integrating some bumper mounting hardware. Quite a few teams have started putting latches to connect their bumpers on similar chassis.
Unread 08-01-2016, 20:04
Will do
Unread 08-01-2016, 20:46
Robotics Engineer
1/8" will definitely be enough. You could probably even get away with 1/16" since they're omni wheels and you don't have to worry about scrubbing.
