Go to Post I, for one, am perfect and therefore make no mistakes. (Unless you count all the times that I completely screw up) - Molten [more]
Unread 10-01-2016, 17:45
dieDoktor dieDoktor is offline
AKA: Kipling Cohen
FRC #4118 (Roaring Riptides)
dieDoktor is an unknown quantity at this point
Re: pic: Tri-Wheel Design
"short lived" why? Any noticeable problems?
Also, I cant see it in the picture, how do you transfer power from motors to the chains inside the triangle?
Unread 10-01-2016, 17:56
Doug Frisk's Avatar
Doug Frisk Doug Frisk is offline
Keeping Score
AKA: Doug Frisk
Doug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond repute
Did one of your mentors love the movie Damnation Alley as a kid?
Unread 14-01-2016, 16:46
ArtemusMaximus's Avatar
ArtemusMaximus ArtemusMaximus is offline
Enginerd
FTC #11722
ArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to all
I am the mentor and no, never heard of the movie Damnation Alley
and now I googled it :S
Unread 13-02-2016, 20:34
callmecairo callmecairo is offline
FRC #2521
callmecairo is an unknown quantity at this point
https://youtu.be/lvpW5RgyZQ
we also had a team member focus on tri wheels without much support. We tested today with success.
Unread 14-02-2016, 11:20
Enginerd
FTC #11722
Tried to see the video, but it does not exist. I very much would like to see your team's implementation.
2017 FTC 11722 (Coach)
2016 FTC 10544 (Coach) Canadian Championship Finalist, Rockwell Collins Innovate Award.
2014 FRC 5064 (Mentor)
Unread 14-02-2016, 14:28
Roboshant's Avatar
Roboshant Roboshant is offline
Design Lead 17, Scouting Captain 16
AKA: Dikshant Sharma
FRC #0226
Rookie Year: 2015
Roboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to all
Video of a team I found on YouTube testing tri-wheel: https://www.youtube.com/watch?v=lvpW5RgyZQw
Unread 14-02-2016, 20:59
Enginerd
FTC #11722
aha, video works now.
It doesn't look like you are driving tri-wheel assembly itself. it may help with the last defense (starting at 0:34)
Unread 14-01-2016, 16:17
Enginerd
FTC #11722
I made it just as a proof of concept without much of teams support. Short-lived because while it was functional, it was seriously under powered. Gearing it down would decrease the speed too much. Without extra motors and a gearbox that would allow to use them to increase torque I couldn't make it work and without team's support I just run out of energy to push it forward.
If you look at 2 motors in between the tri-wheels, they drive axle that connected to the sprocket inside the assembly.
Tri-Wheel assembly itself driven by:
  • Vertical motor
  • 4:1 Worm gerbox
  • Long Axle
  • Sprocket
  • Chain
  • Sprocket (Outside of frame)
  • Dead axle hub
  • Tri-Wheel Plate
Last 3 are connected together.
I hope this helps.
On this photo may be a little easier to see:
http://www.chiefdelphi.com/media/photos/42623
