Go to Post I'm sure there are many people out there who check their rep screen every 20 minutes in hope of positive reinforcement in a unique community, where they may not get positive reinforcement for sharing information in their home, school, or robotics program. - Eugenia Gabrielov [more]
  #34   Spotlight this post!
Unread 11-01-2016, 13:42
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Re: pic: Shooter damaged a Boulder
Originally Posted by dkavanagh View Post
The boulders do compress and take some time to return to full size. Any thoughts on compressing in robot to make a smaller "object" to get into the tower opening?
I don't think this is something I would design my robot around. We're compressing the ball about 3" and it doesn't noticeably change the shape of the ball after it's out of the shooter. If you compress it any more you'll have to worry about things like stalling your shooting motors. Then you can try putting bigger wheels on the gain some linear speed while gearing down the motors. By then you'll notice the shooter is clunky and doesn't fit into tight places where you want it. Then you'll realize wow, this change is causing more trouble than it's worth. Smaller wheels, fine tuned compression, low gear ratios, and high rpm's. Those are the constraints I'd be designing my shooter around.
